Community Atlas - Maelstrom Bay
Hi
This is my first version of the Maelstrom Bay regional map. I mostly focused on the water areas and tried to make the currents visible by drawing blurred lines.
@Quenten: I do agree that the map looked a bit empty. Most of the area is covered with water and adding symbols to this area wouldn't fit the way I worked with the water areas so far. I think adding more texts and more settlements helped a bit.
@Dogtag: Thank you for your advice. I added some more cities outside the bay.
I tried to place some oasis symbols, but the colors did not fit. I'll try to draw some manually.
@Jon: Thank you:)
I think I'm nearly done here. If there are no further suggestions, I'll hand the map in tomorrow.
