Community Atlas - Dworn
Hi guys
Here's my first version of the Dworn regional map.
I'm not quite sure how to do the text. I actually like the map being clean, but I would like to add texts in a subtle manner. Any ideas?
Here's the next update as well as the map notes. I think I'm done here unless someone has any further suggestions.
I'll consider adding a few more names. But I must admit that I do not have a clue on how I should place the names of mountains so they are readable on one hand and still subtle on the other.
Therefore, I'll probably skip the mountains. Looking at the map, naming the Lakes seems to be a valid option. What do you think?
For the mountain names, say just for a couple of the more important peaks, perhaps experiment using "Text along a curve"?
It's $10 shareware but, as someone who's used it for around 15 years, I can say it's certainly proven it's value.
Just a thought for you, or anyone else, who finds names to be challenging.
Cheers,
~Dogtag
I also like the way there are small hamlets without names, as if only the real locals would know them.
I do wonder if those intriguing twin towers at the north end of the vale shouldn't also be named though. They're such an obvious landmark.
And thank you, Wyvern. You are right about the towers... I'll see what I can do about this, since I've already handed the map in.
The program is free and you can download and easily make other enator files for it.
The website for it is at:
http://www.nbos.com/products/inspiration-pad-pro
An online version of some of the additional geneartors people have done is at:
http://www.rpginspiration.com/
(Note: you can download the ipt generators on the second link just look for the little download ipt link.)
Anyway, really like how that map came out.
@Quenten: Thank you very much. I'm not sure if I understand how this program works. Does it just give you a random selection of names from one of the tables or does it generate new names based on the tables?
@Jay_NOLA: Thank you for the advice and the links.
