Help with another problem please. Annual 2011 More Dungeon Symbols
 caveCrawler
                Traveler
caveCrawler
                Traveler
                    I guess it's my day for problems. I am following the CA50 Symbol Guide exactly and the 1500 Symbols are not showing up. For example, after starting a Dungeon with DD3 template, I go to Debris looking for the "Cobwebs" and it's not there. Same for anything else. Am I doing something wrong?
Mac/Wineskin user.
Thanks for any help.
                            Mac/Wineskin user.
Notice the name of the folder. You probably have the same situation.
Anyhow, I cannot find any of the symbols unless I load them manually.
Top
I sent Ralf an e-mail.
Hopefully they can fix this. I don't like loading stuff manually.
The user manual explains the symbol catalog settings and filters, and how to create them. You'll find it on page 83 and onward. (You'll find additional information in the Tome if you have it, but you don't need it for this opeartion).
You'll need one symbol catalog setting for each of the 8 catalogs.
Looks like I will just be waiting on Ralf to fix it.
In the meantime, are you sure your cobweb catalog is blank? The cobwebs are white and, thus, invisible in the catalog. So, you could have done it perfectly and it could still look like it didn't work.
Unzip the files and copy them to your CC3+ program data folder (usuallly C:\ProgramData\ProFantasy\CC3Plus\) into the \System\Symbol Catalog Settings\ subfolder.
You can set this up yourself if you want by editing the symbol catalogs and enable the 'Randomly select from collection' for all symbols in the catalog.
Thanks!
