Questions About Line CC3+
                    Hey Guys,
I am drawing some lines on a map and once I apply effects they are turning from black to green. I suspect one of my effects is doing this. So when you draw lines in CC3+ what layer and style group does it put them in?
Thanks!
Joel Logan
Thanks!
Joel Logan
Joel Logan
So, effects are "grouped" by sheet. Once you know which sheet the line is on, you can click the appropriate sheet in the Sheets and Effects dialog to see the list of effects applied to it.
I hope that helps.
Cheers,
~Dogtag
