CC3+ Save issue
 jpstodwftexas
                Traveler
jpstodwftexas
                Traveler
                    Okay this is really getting to irk me.
Two computer systems
Same problem
When I try and save a Map in CC3+ I keep getting "NOT ENOUGH MEMORY" error
I just tried saving a Map on the New "rented" HP with Windows 10 with 4G Memory
Saved area is 44 5' squares wide...trying to save at 72 DPI...(72x44=3168)
Same problem
Have you enabled anti-alias for that export? If so, what is the value? (You'll want to keep this low)
Doesn't do it everytime
I did a 72 DPI 36 wide map and saved it
Where are you saving them to ?
I save mine to a folder outside Programdata and outside program files.
