Moving Symbols to New Sheets
                    Hello, all. Still relatively new to CC3+, et al. and I have a question. I want to place items so that they appear to be underwater. I create a new sheet (UNDER WATER) then select my symbols (rocks, usually) and click on the sheets bar at the bottom to make it UNDER WATER. I place the symbols down, but they still end up on the SYMBOLS sheet. I have tried clicking the new sheet before and after my symbol selection, and the sheet shows as the active one, but still the symbols go to the SYMBOLS sheet. What am I doing wrong? The idea is to put certain symbols on the UNDER WATER sheet and then use the TRANSPARENCY effect on it so that it "fades" into the water.
Thanks!
ScottA
                            Thanks!
ScottA
