CC3 crashing often
                    Hello everyone.
CC3 and DD3 are crashing very often. usually when i zoom in or out, or when i drag the map so i can look at a different part. previously i had an issue with it crashing when i imported a FT3 outline, someone told me it was due to too many nods. but when i start a fresh map and i make the land mass using the default land mass button it still happens. i have erased the program and re installed. i have repaired the program. i am using version 3.43. i am running windows 10. i cant go more than 2 or 3 minutes without the program crashing. this is becoming a really big problem since i paid for a lot of things that only use CC3 and not CC3+, and now they are all becoming redundant. CC3+ is not crashing so far, but i dont use it very often but i fear that i will have to make the change soon because i am at a point now that I've given up on this program in general. I desperately need to resolve this and any help would be appreciated.
my rig is high end and i have even tried installing on my laptop, and the program crashes on both my desk top and my laptop. so i believe it is something inherently wrong with the program or some setting that is activated without my knowledge,
does anyone else seem to be having this problem as well? and have you managed a way around it. any suggestions that don't involve "use another program" would be very helpful. Thanks in advance.
Both are still 32-bit programs and will still have the limit of those programs in place, however, CC3+ code has been refactored to enhance performance and reduce resource usage - which is the problem you are running into.
CC3+ is the way forward anyway as CC3 will be phased out.
The ones that I know of that are not are:
The Cartographer's Annual Number 1 through 5
Source Maps: Castles
Source Maps: Temples, Tombs & Catacombs
Source Maps: Cities
The WW2 Interactive Atlas
The Forgotten Realms Interactive Atlas (this one will probably never be updated as it was a one off project with Wizards of the Coast)
Everything else should have a CC3+ update to them so for the most part you should be in good shape with upgrading to CC3+
The Cartographer's Annual's are being updated fairly quickly compared to the past so I suspect it will only be about five more months before all of them are done. They have been upgrading them about once a month recently.
EDIT: Another advantage to upgrading to CC3+ is that the program is more stable. So less crashes. And another is that with CC3+ they have added Photoshop like blend modes to the program, which you cannot do with CC3.
I have never found a way around the CC3 program crashing when I zoom in using the mouse. So I always use the zoom functions with it (sadly, even then, If I have the Sheets and Effects turned on when I do so it will still crash. CC3+ does not have this problem.)
As have been mentioned earlier, I too really recommend switching to CC3+ though, as it is both MUCH faster and more stable. As for add-ons for CC3/CC3+, they are being converted continuously. All the major add-ons and symbols sets (except dioramas) are already available for CC3+, all but the 5 first annuals are available (the rest are coming). The Source Maps are still missing. And everything that is available is a free upgrade if you own the CC3 version, so the reasons to run CC3 instead of CC3+ are quickly shrinking. And most new products that arrive are also CC3+ only. Only for some, I don't have any problems with that at all on any of my numerous installations. There is a know issue if you try to scroll without the CC3 window being active though. CC3 is still being supported, but you'll need to put in a support ticket to receive official support.
I also have experienced a lot of crashes in CC3, especially on larger maps, when using the scroll wheel. A way to deal with it is to save a lot, but the crashes are still annoying. Which is why I use CC3+. As for the addons, they are being updated at a quite fast pace. If you want one of the first annuals in CC3+ you'll also find instructions on this forum on how to update it yourself, if you don't want to wait.
As said, I too recommend switching to CC3+, for your workflow will increase quite a bit.
– Volume 7 update released Feb. 27.
– Volume 6 update released Mar. 10.
– Volume 5 update will probably be available fairly soon (though, again, that's unofficial — I can't speak for ProFantasy).
That's about 1 - 2 weeks between each update recently. Just sayin'.
~Dogtag
Thanks again for doing that Dogtag
