Something odd encountered
 Topdecker
                Traveler
Topdecker
                Traveler
                    You are looking at a bitmap filled smooth polygon with a bevel effect (6 map units) applied.
Now you are looking at the same thing (well, 8 map units) on another sheet. I am simply hiding the previous layer on the cliff I am crafting.
I have no idea what it is doing or why. Any ideas? Probably should bug report it, but thought that I would check in with experienced folks first.
EDIT: Source image is a VH quality bitmap (40 map unit scale)
Tim
Tim
But if increasing the size of the bevel effect helps, then that's a start:)
Feel free to attach your fcw. and i'll show you what i mean if i didn't explain it well enough
Thanks!
Tim
Still, if there is a way to dupe sheets, that would be good to know.
Copy by 'move sheet' under change properties, or copy the bitmap, and thern move it to the new sheet.
There isn't means to click and bring up 'dupe sheet' that I know of.
You can right-click on the Copy command and select "Copy to Sheet" to dupe an object (or objects) to any sheet.
