Custom Tool Properties Feature Request
I was unable to find anywhere for making a feature request. So I'll post this here and hope someone tells me where to do this proper or one of the Profantasy guys sees it.
I would like to make a request that in some future update, the Textbox for Sheet in the Custom Tool Properties dialog box, be changed to a ComboBox, so I can select the sheet I want rather than having to remember to write it down prior to opening the modal dialog.
I'd really, really, appreciate it.
Thanks
Thanks
This also allows you to make a tool for a sheet you don't currently have in your map, the tool will create that sheet on first use (Of course, this also opens up for misspelling)
I guess what I mean is, there is a programmable way to accomplish it, which is likely more trivial than 99% of the rest of the software.
