Error installing Cartographer's Annual 2008
I purchased the Cartographer's Annual 2008 (Vol 2) and successfully downloaded the product to my PC.
However I see the following error message when I attempt to install the Annual 08 with the InstallAware Wizard:
"CC3 Not Found
The Cartographer's Annual 2008 is an add-on to ProFantasy's CC3 map-making software. Setup cannot continue because it couldn't find CC3 on this system.
Please install and run CC3 first."
I'm currently using CC3+ on my PC so Setup shouldn't have problems detecting CC3.
Any ideas what's going wrong?
"CC3 Not Found
You have to install each separately because they are two separate programs. The Annual will only work in cc3, not cc3+
Looking through the CC3+ tool menu last night, I saw that there are already lighting effects options available in CC3+ (which was one of the main reasons I wanted to download the Annual '08). Maybe I don't need the Annual '08 after all?
A few of the older annuals were also designed to show up some of the add oms. Not sure if any of the Source maps stuff was part of them.
