Resizing Icons Map-Wide
Howdy folks. I'd like to resize the tree's I've laid down on a portion of a world map .. is it possible to choose them all and resize them in one fell swoop for ease and quickness ? Your time is appreciated !!
GAME ON !!
Shadowpath.
    Hi there,
    there are two ways to do this:
    1. Use the Symbols > Scale Symbols in Map command. This works best if you can easily select the symbols you want to rescale.
    2. Open Symbol > Symbol Manager, select all the symbols you want to resize and use the Scale button. This works best if you want to scale all references of specific symbols.
    Note that the second option affects the underlying symbol reference and will therefore be reflected in all future symbols of that type you add.
    Hope that helps.
  • Posted By: Ralf...Note that the second option affects the underlying symbol reference and will therefore be reflected in all future symbols of that type you add...
    Just to be clear, editing the symbol definition this way is reflected in all future symbols of the type you add IN THAT MAP. CC stores the symbol definition in the map, and you're just changing that local copy, which is global for that map.
    Steve
