I installed 2015 Annual in CC3+.. now what? Where is it?
 caveCrawler
                Traveler
caveCrawler
                Traveler
                    Hi Everyone,
I installed the 2015 Annual into my CC3+ (wineskin on Mac), the install went fine. However, I cannot find any evidence of the Annual being installed. No additional buttons that I can find. Wasn't I supposed to get some pdfs also? What am I missing here? Thanks for any help.
C:\ProgramData\Profantasy\CC3Plus\Annual
I have C:\Program Files\Profantasy\CC3Plus but there is no Annual directory.
C:\users\Public\Application Data\CC3Plus\Annual
Following the PDF, I still get none of the 319 new symbols that OSR Dungeon Map issue promises.
Any help would be appreciated. Thanks.
Most of the annuals are product-independent though, but provide extra advantages if you have the related products. Generally, if you use an annual without the associated add-on, you will need to do more manual work, a few examples may not display, but they are still usable.
But it will probably always be some workarounds needed from time to time.
I draw rooms and corridors and do the hatching around it and it works great. Hatching is UNDER the rooms/corridors. Caves are another story however. I cannot get the hatching below the caves under any circumstances. I am trying to use caves with a 10' grid filler if that makes any difference. The walls of the caves are a no-show so I use Trace to get the cave properly outlined but the hatching is ruining it. What could I be doing wrong? Thanks for any help.
