Adding a bitmap tile to a section
 JMunsonII
                Traveler
JMunsonII
                Traveler
                    Greetings!
I've taken copies of two of the Schley PNGs, Water Blue 5, and shifted the color a bit to make 'bloody water.' Now, I want to have that show up in the choices for texture. I've added the two files back to the appropriate folder, however, CC3+ doesn't pick them up. Is there a list somewhere that needs to be appropriately extended? Or, how does one add textures to an existing pack if that's the really wrong way to go about it?
Thanks!
Jon
Thanks!
Jon
I'll generally advice you to keep your custom bitmaps in a separate folder though, and not copy it in with the other ones, this makes it a bit easier to manage your custom stuff.
