Issues With Output
Hi Team...
This is what I'm looking at within CC3+ prior to a save: Prior to Export
But when I save as a JPG / BMP I get this: Post Export
Am i doing something wrong?
- Make sure that the fills you are using have the "Scaled" option set (and resonable values for the scaling size) in the fill style dialog.
- Make sure that the effect units for your effects is set to map units or percent of drawing extents width. The Percent of view width is very rarely appropriate, since this changes the effects based on your current zoom level (And pretty much guarantees that they will be different on print & export)
