Scales in kms
Hello, I seek scales to graduate in kilometers.
I find only scales in miles and I do not manage to modify the texts All that for CC3
Thank you
    Are you refering to the scale bar?
    If so, you can just use Explode image [EXPLODE] on it. Now you can use numeric edit image [EDIT] on the "Scale in Miles" text, and change it to whatever you like.
  • I tested by selecting in entirety the scale.
    Then I make edict text by selecting “scales in xxx” and Ca functions.
    But I do not arrive there with your method.
    Thorn
    Did you make sure to properly finish the explode command before editing the text (i.e. by making sure it got actually selected [The command line should say that 1 entity is picked], and then finishing the command properly by right click -> Do It) ?
    Also, the scale bar might be on a frozen layer, so you may need to go into the layer dialog and unfreeze (thaw) all layers first.
