FCW32.exe crashes at launch (Solved)
                    Hi All,
So after a recent re-install of SS2 cc3+ now crashes upon launch with the error FCW32.exe has stopped working.
I am able to repair cc3+ and it will launch fine immediately after the repair is complete. However once i close the application and try and re-open it. it does the same thing.
I also installed cc3 and all my addons and it seems to work fine. This is only happening with cc3+
Using Windows 7 64bt
Any advice?
Any advice?
try open a map, instead of the program.
Hi Cobra, i thought that too, but still get the same thing.
I know the install programs do install them correctly, but computers sometimes does weird things.
What i find interesting is even after the install of SS2/SS2+ i dont see its ss2.mnu file in either folder... is this somehow just integrated into DD2+?
Coincidentally, I think this is what started this whole thing as i attempted to install it (SS2) yesterday thinking it wasn't installed. Hmmm.
Also, SS2 doesn't have it's own menu file (Neither does SS1)
However i did find a work around of sorts and this may be obvious so not sure what i didn't try it at first. But things work as long as i right click on the desktop icon and choose "run as admin".
Not a big deal i suppose but i never had to do that before. But i can live with it.
Good to know on the SS1/SS2 btw, thanks.
Try this:
- Right-click the Campaign Cartographer 3+ shortcut icon and select Properties from the pop-up menu.
- On the Shortcut tab, click the Advanced button.
- Check the Run as administrator checkbox, and then click OK.
- Click OK
Now, whenever you double-click the shortcut icon, it will open CC3+ as if you had right-clicked and selected "Run as administrator!"The Campaign Cartographer 3+ Properties dialog displays.
The Advanced Properties dialog box displays.
The dialog box closes.
The Campaign Cartographer 3+ Properties dialog closes.
I hope that helps,
~Dogtag
So now im off to install the annuals and the "John Csuac" assests :P
Thanks Everyone for you help and have a wonderful holiday!
