CA3+ Arm Symbol Problem
 Shessar
                🖼️ 34 images Mapmaker
Shessar
                    There is a problem with the "Human Male Thin Left Arm 2 Shirt Sleeve" . The Vari-color map does not line up with the symbol.
Has an update/ fix ever been posted for this? I don't want to download the installer again if it hasn't been reported/fixed yet.
Thanks!
Thanks!
I have not been able to find a way around the issue that you have neither.
Hopefully Ralf can fix it upon his return. :-)
I figured that you would know if it had been fixed or not. I consider you the CA expert on the forums.
Because the arms are in different positions depending on what side it is, you would also have to mirror everything else as well (arm, weapon, glove, etc.). You would also have to change the sheets that the items are on. It is a great idea though. It is already giving me ideas. LoL! ;-)
But happy to be of some small assistance
I created a Sabinian Gladiator and used the same arm for both sides.
Besides mirroring, I had to change the sheet to ARM LEFT, Change the sheet for the armor to ARM LEFT ARMOUR, and change the sheet for the Gauntlet to ARM LEFT GLOVE. I did not have to change the sheet for the weapon.
Below is the example.
Happy accidental suggestion
These are still works in progress.
