2015 Annual Battlemap collection red X
I bought annual 2015, and then installed the BattleMapCollection that was listed as free. But 3 of the maps in that collection are showing red X.(forest path, razoredge 2 and Forest camp) Reading some threads about this problem, I listed some of the offending images(one is shownon image 2) and took note of the supposedly missing bitmaps. But the thing is, I can find all those bitmaps/symbols in cc3+ data folders.(see image 3) So why are they appearing as X when they are present? Any way to fix this? I should also add that the doc mention using art from DD3, SS2 and CSUAC and all 3 are installed.
    Those maps were made using a previous version of the CSUAC. From the paths in your screenshots, you have version 2 installed, which uses slightly different file paths. If you use list on the symbol definition itself (accessible from the symbol manager), and just a reference, you can see the actual path used.
