Perspectives 3 - Cut hole in a wall?
Hi Team,
Is there functionality to cut a hole in a wall with PER3?
Like if I create a room and want a door in one of the front walls, putting a door symbol looks wrong because the wall obviously blocks the back of the door.
I would usually break/split the wall and move things around but I can't figure out how to work with the walls at all. Node Edit doesn't let me move a wall.
I'm surely failing at an epic level
I recommend deleting the entire wall, and just use the wall tool to draw two new walls (one on each side of the door).
Was spoilt playing with the DD3 wall features
