Mis? Behaving Hill Symbols
 LordEntrails
                Traveler
LordEntrails
                Traveler
                    Started a new map yesterday, following the steps (mostly) in the first map tutorial in the CC3+ user manual, but doing different geography.
So, did a bunch of work yesterday. When I open the map today to continue placing my hill symbols, They don't behave the same way. They are different sizes and some of them have different fill colors. See image, on the top right you can see the mountains and hills I did yesterday, in the main part of the image you can see what happens when I try to place hills today. Some come in like yesterdays, some are larger (even though it indicates scale is the same (.175) and the fill color is different. I'm using the "Hill 1" random symbol family.
I can reproduce this with the following steps:
- Open CC3+ (loads map automatically)
- select Minerals/Mountains to get proper symbol catalog
- select Hill 1 and start to place symbols, can use tab to toggle to other random hills.
Using CC3+ v3.75
Thanks
Using CC3+ v3.75
Thanks
Nowadays I save my palette just before closing, and then reopen custom palette as soon as I open the file again to restore the colours I so carefully modified the first time around.
This may be what the colour problem is, but only if you modified the colours in the first place.
I did see this post, maybe they are related? http://forum.profantasy.com/comments.php?DiscussionID=6578&page=1#pgtop (But, again, this is a brand new map, never even had CC3 installed on this computer)
You can switch between symbol styles by clicking the symbol style toggle button in the left toolbar. Right click it for a list of options.
Yes - changing the varicolour fill colour is just a simple case of changing the colour at the top of the screen by clicking on it, or one of the colours in the toolbar palette. I think you can change the properties of existing varicolour symbols using the change properties button - the paint pot button. If you want to do more than one at a time use the topmost paintpot and select them all at once.
EIDT: Oops! Sorry Remy... and Dogtag
My bad!
Also, why would that change on it's own? And it looks like it's still set correctly...
(Oh, and thanks for everyone helping out!)
Anyway, your map is a Mike Schley map, so the symbols you get now is the correct ones for this style. Unfortunately, it looks like you for some reason had the wrong symbol catalog open yesterday, which caused you to place hills/mountains from the standard overland style instead of the Mike Schley style you were supposed to. If you wish to continue with the wrong symbols (Since you already placed a good deal of them), you can use the symbol style toggle button to toggle your symbols to the standard overland ones.
It had something to do with the company using the same file name in multiple styles.
May be the same problem.
The advise that I was given was to create a custom symbol catalog.
I never got around to going through that endeavor, but I believe it was Monsen that suggested it (Apologies if I got the wrong person).
I have just been dealing with it.
