FCW32.exe has stopped working error
I am getting a FCW32.exe has stopped working error.
I was working on pulling up a pdf from the annual folder to look up how to make custom symbols using the Ancient Realms template.
When I tried to go back in to my map - I got this error.
Any help would me nice - I am dead in the water.
Thanks
Thanks
I get the same error.
I will try the update and see what it does.
Thanks Ralf
If that still doesn't work, try a Repair install of CC3+.
I am not sure what you mean by Repair Install.
I have not seen that as an option.
I did try something else, right clicked for options and tried "run as administrator" and it works that way.
Any idea what is causing that?
Thanks!
A repair install happens if you re-run the same installer package. You will get offered to "repair" or "remove" the program. But if you used a newer setup file than the one you originally used, you wouldn't see this option.
