Trace
I am trying to use trace to make a road around the inside of a semi-circle attached to straight lines. However when I use the trace command it only goes through the middle of the entity. ANyway to get it to go to one of the edges?
If this is unclear, let me know and I'll give more elaborate instructions.
The sheet will always be the old entity's sheet. Use "Move to Sheet" to send the offset entity to a new sheet.
