Missing buttons.
ok i just kinda came across another bug. after preforming a full update including CD and DD for CC+. i notice that all the buttons are missing. i tired repairing the base program, which did work. only to find out that by repairing it. it also broke the features of cd and DD. i tried repairing cd and i lost the buttons. the buttons themselves are still functional thou. it just appears that the bars are blank.
When you say a full update what does that mean?
What exactly did you install/update?
In what order did you install/update it?
Did you remember to switch off your antivirus software before installing/updating the software?
Did you install/update everything as the administrator?
i did not switch my antivirus off. thou that had little to no effect on it as it considered this program a safe program. and i did everything in administration.
that said the base CC+ works without any issue. but when i add cd or dd the buttons becomes invisible. i can still click and use it. so this has to be more of a glitch.
hears the image of the glitch.
https://www.dropbox.com/s/944y2tng0h00hwa/bug 1.png?dl=0
Another ting to note about the patch is that in addition to installing the latest files, it also runs maintenance on your menu files, so even if you already have the latest version, running the patch can fix problems with your installation even if it doesn't actually intall anything new/updated.
