Tried the style in the new annual...
When I seen the new style in the annual I decided I should try it quickly. Since it is just a quict test, and no "Real effort" was put in it to make it something nice, I would say the results are better than what you would expect.
You can download the map from Cartographer's Corner blogs post about the new style in the annual.
I should be working on it, but it won't be that easy
No, I haven't been following the inn-design project. Did you post about it?
