UPDATE: Bogie's Objects & Update 8
2»
    This server really is a pain. It must be causing quite a deal of embarrassment, which is horribly unjust, given the marvellous gift you have worked so hard to give to us for free. You have my sympathy entirely.
  • VintyriVintyri Traveler
    Posted By: LoopysueThis server really is a pain.
    Actually, until just recently, it was about as sturdy and reliable as can be. I suspect equipment updates are going on now - although no one has said that - and when that's over, things will be stable again.
  • Posted By: Vintyri
    Posted By: Scott DHere is my symbols folder
    The symbols aren't showing up because you haven't installed them ... or if you have, then in some place that doesn't show up in your screen shots.
    However, that just tells you what's up. It doesn't help you do anything about it. To help you, it might be a good start if you told me which Vintyri file(s) you downloaded.
    I downloaded cc3plus_bogie_setup from http://www.vintyri.org/vintyri/bgindex.htm. I didn't get an error message on the install. What do I do to add the missing folder? Thanks.
  • My question seems to have been skipped over so I am reposting it - Thanks.
    Posted By: CharlesWayneRobinsonQuestion, I do not have any of the Vintyri updates, will updates 7 & 8 negatively affect me?
    edited July 2016
    Posted By: Scott DI downloaded cc3plus_bogie_setup from http://www.vintyri.org/vintyri/bgindex.htm. I didn't get an error message on the install. What do I do to add the missing folder? Thanks.
    Run the setup program again. At the start, it will remove the faulty installation and then reinstall the whole thing. When you reach the point in your setup where you see the dialog box below, be sure that ...
    C:\ProgramData\ProFantasy\CC3Plus
    ... and nothing else are in the field named "Destination folder." The screen shot that you sent shows rather conclusively that this is not where you installed the first time.
    Before running setup, be sure to temporarily turn off your anti-virus program, and be sure to run as administrator. Not doing either sometimes can result is some objects not being installed without notice or warning.
    Sorry about the delay. I attended a meeting last night and then got a good night's sleep on European time, so I only saw your message this morning.
    edited July 2016
    Posted By: CharlesWayneRobinsonMy question seems to have been skipped over so I am reposting it - Thanks.
    Sorry. In going through this long list, I somehow missed this query.
    Update 7 apparently makes problems for some people, regardless what they have. Update 8 seems to run better. Their performance has nothing to do with any Vintyri product. I hope that answers your question. I'm not sure what you mean by "Vintyri updates," but my answer should cover it.
    I see several posts with your name in the subject line, so at a wild guess on my part, those might be what he is refering to.
    You would be right there, Jim. Hopefully we will have all this sorted out before too much longer :D
  • Thanks Vintyri!
    Yes, you answered my question.
    I do not have the extra symbols sets and the Bogie sets. I only have the CC3+ products from ProFrantasySoftware.
    I will wait for the bugs to be fixed in the updates before I use them.
  • 10 days later
      I did as you said, but still no cartographic collection. I downloaded it again and tried the new install file, but that doesn't work either. I don't see a folder for it in the symbols folder either.
      edited August 2016
      Make sure you direct it to your data folder for CC3+. C:\Program Data\ is not normally visible.
      Posted By: Scott DI did as you said, but still no cartographic collection. I downloaded it again and tried the new install file, but that doesn't work either. I don't see a folder for it in the symbols folder either.
      And what do you see when you call up CC3+? What exactly is the path to your CC3+ data folders? There isn't enough information in your posting to know where to begin helping you.
