Problem with creating symbol set
Hello,
I try to create a Symbol Set for Shadowrun Security Symbols.
I use the CA14 Annual Mapping Guide.
When I look into the Symbol manager then everything looks fine.
But the Preview looks very ugly due to disturbing huge numbers.
And when I use the Katalog in a drawing I get this huge numbers also and have to delete each number.
What was my misstake by creating the symbol set?
With best regards
Robak
With best regards
Robak
It looks to me like everything is doing what it's supposed to do. Can you give us a better problem description?
The Symbol Preview Picture -- visible in the second Screenshot of this thread -- shows minimum 5 times NOT the Symbol.
This is the case vor Transp_Lock 6, 7, 8, 9.
The Symbol Preview Picture shows a HUGE 1 and a tiny dot at the left bottom sied (which is the Symbol).
Also the placed Symbol is not only the Symbol but also a very very very HUGE '1' (ZOOM out!).
I have attached a placed Symbol (tiny) with a very very very huge bing '1'.
The huge '1' is never visible in the Symbol Manager (-> Scrennshot 1)
With best regards
Dietrich
If you execute the list command on the symbol, you can see that it contains a huge text entity To get rid of this, you will need to just edit each of the problematic symbol in the catalog, and simply erase the text entity.
