Display Resolution in CC3+ on 3840x2160 Screen
 Kathleen Ann Cox
                Surveyor
Kathleen Ann Cox
                Surveyor
                    I just got a laptop with screen resolution of 3840 X 2160. While CC3 displays normally (sort of), CC3+ displays with the icons so tiny on the bars, I can't even identify them. Is there some way to go into the settings and change the display in CC3+. So far I haven't even been able to figure out a practical work around for this issue.
Thanks!
                            Thanks!
To display large toolbar buttons in CC3+:
- Click the Tools button. It's the small button with the hammer icon at the bottom of the screen, after the command line and next to the Grid button.
- Select (check) the Use large toolbar buttons checkbox, and then click OK.
- Close and then reopen CC3+.
I hope that helps.The Select Screen Tools dialog box displays.
The dialog box closes.
Cheers,
~Dogtag
Thanks for your response. You are always very helpful on the forum. Unfortunately, changing the screen resolution doesn't help at all (I tried). The frames or windows don't align and the tool bar icons are nano-sized
- You change the actual resolution and not the zoom factor (Windows 10 hides the resolution away, under advanced settings)
- You log out and back in. Windows still struggles with applying resolution/zoom changes on the fly (Even modern MS software like Office 2016 struggles with this, I can give you some nice screenshots of how powerpoint behaves when disconnecting from a projector for instance [Hint: Microsope required])
You are the best. I am both happy and embarrassed now. Happy because it works. Embarrassed because I thought I had restarted my computer but I must not have. It's not a perfect situation but it has made map-making possible in CC3+ which is what I wanted.
Thank you for taking the time to help me resolve this!
Cheers,
Kathleen
Monsen,
Any idea when/if some improvements will come along for UHD resolution on a smaller screen with the CC3+ suite? Just bought the initial 3 but finding it extremely difficult to navigate effectively given the tiny icons/text on the navigation menu. Even with display settings fonts turned up, resolution changed, and big icons turned on in CC3+ it's still pretty hard to see/distinguish specific icons.
This is still pretty much what my screen looks like. And if this was a 40" or bigger screen may not be an issue, but I'm working on a 17" UHD laptop screen. (Edit: Nevermind, pulled picture, it was waaaaaaaaay to big... Picture was displaying larger than my actual screen size.
Will try to make it work by attaching a 2nd monitor with small)er native res, but definitely going to consider that return policy based on outcome.
