Can't save cc3+ maps
 jpstodwftexas
                Traveler
jpstodwftexas
                Traveler
                    No Matter what I try to save as I get a "Not Enough Memory" message...always fails to save
Getting very frustrated..
2. Does the task manager show you that you have physical memory available?
3. Try clicking the CC3+ symbol with the right mouse key and then pick the option "Run as Administrator." If this solves the problem, your Windows UAC settings are too restrictive.
4. If problems persist, you can try to run the CC3+ installation program again and then pick the option "Repair."
5. If none of this helps (not totally unlikely) send a trouble report to ProFantasy technical support.
Today cc3+ won't even open
Unistalled cc3+ ...
reinstalled CC3+ using updated installer
Nothing worked except the new art style..
Would not Zoom in...
So I going back to uninstall cc3+ ..uninstall DD3+...Uninstall CD3+, Uninstall SS4+ sets
Re-download CC3+ and then Update again...
This has been a Nice 3 hour project so far...
Made a Map..tried to save...won't save
Where do I change save settings to see if I can find a size it will save as.
As an example: select png, then click on options, lower right. There is a place for height and width. You can select 'crop image to aspect ratio' and/or 'restrict edge to map border'.
