CD3 hi-res bitmaps (CD3Bitmaps.exe) won't install for Windows 10
                    Already consulted the following threads:
http://forum.profantasy.com/comments.php?DiscussionID=3640&page=1#Item_11
http://forum.profantasy.com/comments.php?DiscussionID=2440&page=1#Item_4
It's basically the same problem:
updating CC3, CC3+, CA3, CD3, DD3, SS1, and SS2 and some of the free software that came with the package...
particularly in this case: CD3Bitmaps.exe
the following error occurs repeatedly:
"Sorry, your previous CD3 installation could not be located.
Please install and run City Designer 3 first."
Running on an ASUS laptop, Windows 10, installing on drive as best as possible
 as best as possible
I've tried repairing CC3/CC3+ several times, and CD3 and CD3 for CC3+ several times
I've tried running CD3Bitmaps.exe as administrator as well.
Windows 10 is as up to date as possible.
I've set the firewall permissions for the ProFantasy software as high as they go, and I'm runningCD3Bitmaps as an administrator.
No Joy. Still doesn't make a difference. Same error.
Previous people addressing this issue seem to indicate same type of problem, same type of attempts to fix it, don't know about results exactly.
I'm hoping to find a resolution to this issue and will provide feedback.
I appreciate any help that anyone is willing to provide.
 as best as possible
 as best as possibleI've tried repairing CC3/CC3+ several times, and CD3 and CD3 for CC3+ several times
1. Using "Run as Administrator," open CC3 (not CC3+!)
2. Start making a map with CD3.
3. Close CC3.
4. Don't do anything else before you try the next step.
5. Run CD3Bitmaps.exe again.
Agreed. That might not work. But based upon what you wrote above, it sounds like it could.
I am trying it now...
[Jeopardy theme song plays as the clock ticks the lag away....]
I did as you suggested:
run as admin CC3, built a new CD3 map and saved it, closed CC3
run as admin CD3Bitmaps.exe
No Joy. Same error.
I appreciate the feedback though. Maybe it's closer to a solution? I have no idea.
I'll try rebooting, that's always good for a laugh.
Rinse... Repeat.... No Joy... Same error. Sigh.
I hate breaking into the regedit without sufficient clues where I'm going, but.... lol
Thank you, btw, JimP. I know that you were one of the original posters from the original threads on the topic(s).
Support ought to be help you with this.
\HKEY_CURRENT_USER\Software\EvolutionComputing\CampaignCartographer3.
