Switching terrain catalogs
I started a map using the terrains found in CC3 - SS1b Fantasy, but want to use terrains from Midgard World and DeRust Overland found in the Annuals Volume 7 as well. I am lost on how to switch the catalogs... I would elaborate, but I really don't know what I"m talking about on a technical level. Hopefully someone more versed with these programs can read between the lines! :-) Any help or advice would be greatly appreciated!
Now, to draw terrain in the style of one of the other maps, click the all drawing tools button in the lefthand toolbars, and change the style dropdown at the top of this dialog to either the midgard world or the DeRust styles to see the drawing tools from these styles. Since you imported the fill styles using the above procedure, these tools will now work.
Do note however that these tools are designed for another map style, so they may not use the same sheets as your map, and the effects on your map may not look properly with those tools, so you may need to tweak sheets and effects when doing this.
