How do I fix this? Happened three times now!
 LadieStorm
                🖼️ 50 images Surveyor
LadieStorm
                    I don't understand what's happening.  I've been trying to post my maps to the show and tell area, and everytime I try I get this:
Some problems were encountered
The file you attempted to upload (Ardenvale2.PNG) was empty.
You are not allowed to upload (Ardenvale2.PNG) the requested file type:
I don't get it. I've created a lot of png files, that I've uploaded here. Why all of a sudden are my png's empty? My fcw's post just fine. Did I mess something up in my settings? I have the antilias on, and I just realized my antilias is set to 0%. I'm assuming this is why my png's are empty? What antilias be set to?
That was supposed to be What should antilias be set to?
The files you fail to upload to the forum, have you tried opening them in an image editor on your computer? are they fine there? If not, what is their file size?
And don't forget, you can edit your posts to remove mistakes
I bring the image up in Paint and then resize to 800 pixels and save.
This normally comes out pretty good.
At first, my images were "fuzzy" looking because I was doing strait screen captures.
One I switched to Save as Rectangular PNG (running 6,000 to 8,000), they came out so much better.
Make sure that when you save your PNG, that you have not symbols in it (such as ' or !).
It will not upload correctly to the forum.
Hope this helps! :-)
I'm concerned that when I go to print out these maps, they won't print...
For size guidelines, check out Ralf's sticky post.
