Altering sheet collections
As many of us already know when you create a dungeon, overland map or anything using CC3 you have built in sheets. When you alter those built in sheets and save them as your own sheet collection it seems to overwrite the one that is there. Is there a way to keep that from happening? What am I missing?
I forgot, you can also create a whole new sheet, and alter that.
But I found out that if you made a sheet and then used it right away to create something on the map, then it worked.
Not sure why.
