items vanish
 IceniQueen
                Newcomer
IceniQueen
                Newcomer
                    I have notice and I cannot figure out why, but in CC3 I draw a map, then I start playing symbol furniture/item's and if I zoom out or redraw they vanish. If I remove the map piece I find them. I have tried to bring to front, push behind nothing works. Any idea on what I need to do to fix this?
I have checked layers, and cannot fix through layers
It does not matter what I place, it vanishes. I can draw a line, a circle, place an object and have it vanish when I refeshed, or zoomed, or moved. If I go to delete the item, it shows up and I can delete it, it just will not show. On an oddity to this, I had this happen many times, closed CC3 and even CC3+ and reopened, drew something,m had it show, saved, drew something else to have it vanish.
I am no expert and very much a noob who has been playing with CC since 2, so i admit, I am a hack at doing things wishing she was better
Open the software and go to help and select Quickstart Guide. You will notice that a lot of the concepts are the same from CC2 but sheets is entirely new concept introduced in CC3. You can also find more info on the sheets section of the User's Manual.
It sounds like you have this:
symbols
sea
land
you need this:
sea
land
symbols
The top sheet in the list is drawn first. The bottom of the list os drawn last.
In the sheets it goes like this
Common which is checked
Background
Background City
Fields
Water/River
Roads
Walls Dikes
Buildings Low
Walls
Walls Top
Buildings
Symbols
Vegetation Trees
Screen
Text
Grid
Map Borders
I tried to move background down and lost everything
I move roads up, and background down a few, got most back but roads were very faded
If you are not using the provided tools in the software, such as the LANDMASS tool, the ROADS tool, the RIVERS tool, etc., which place their entities in the correct sheets and layers and have default settings; you will have to manually select the sheets, layers, colors, line width, fill and fill style for each entity before drawing it.
