Yet anotber newbie question
Hey, this is hopefully an easy question to answer. Is there a way to add more.font styles.to cc3+? I gave some really cool fonts I would like to use on my maps... And the fonts in cc3+ are a little too modern for what I want.
After you have installed them, I would suggest you restart the program (not sure if it is required, but it won't hurt). Then select the text tool, click on the "Properties" button, you've got a selection of the available fonts. Then you click on the "More fonts" button, and in the "System font" tab you should see your newly installed font. Once you select it here, it will appear in the sort-listed fonts of the previous dialog.
Hope this helps
