How do I change the fill color of a forest tool? Nothing is working.
I am a new user of CC3 (first post as well). Im in a bit of a bind due to my ignorance.
What I am attempting to do is change the default fill color of a forest fill tool. Right now all the forest symbols and fill tools use the same color, a light green. I want to create a darker, moodier forest color for use as ancient forest, which would stand apart from the standard forest look. Ive tried a number of things, but nothing is sticking. Ive tried the change properties button along the left side, and choosing the color option on the drop-down menu, and then selecting a section of forest on the map, doesnt work. Ive tried going into the custom drawing tools, selecting a fill style such as Terrain Default, Forest Mixed, and changing the color there; while Im able to go into the properties and change the color, it doesnt effect the fill style, so Im clearly not understanding that either.
Any help would be appreciated!
    Generally, a color change will not visibly affect a bitmap fill style. Only vector fills (Solid, hollow, etc.) can be changed this way.
    You can use varicolor symbols. Load the Vegetation symbol catalog and scroll down, you'll see varicolor versions of the various trees. Change the current drawing color and they adjust to match.
  • Ok so I cannot change a fill style. Unfortunately Im doing a rather large forest at a significant level of detail, so using individual tree symbols would be problematic, I really need to use a fill tool. Back to the drawing board.
    edited February 2016
    Hi MichaelKCC. Welcome to the ProFantasy forums and to CC3/CC3+ !
    You might want to experiment with the RGB Matrix Process effect. To do so, add the effect to the sheet where you place your forests, and play with the effect settings. Be sure to save before and after you add the effect so you don't have to re-add and re-set the effect if there's a problem. That effect has a bunch of possible settings to tweak. I'm sorry I can't tell you more. I honestly don't know if it will do what you want, but I've seen maps that used it to good... er... effect. I know the effect exists but I've never played with it, myself. Maybe Ralf or someone else can give you some additional suggestions.
    Good luck!
    ~Dogtag
  • 8 days later
  • One of the GS that I have do e, and I'm a newbie too! Is what Ralf suggested. If you click on the tree symbol, at the top left, there are terrain fills there as well. I believef there is a forest fill in that symbol pack that allows you to change the color. And here's a thought, thou I have NO idea if it can be done but I don't see why not.... Why not create a darker green contures fill to go UNDER your forests? That with the I need edge fade to soften it a bit might give you the darker feel you want. I admit I don't know how to do it....but if it can be done, that may be an option.
