My river tool draws farmland
I try to draw a river and instead get a line that is filled with farmland. No clue why. Can't stop this. Does anyone know why this would happen and how to go back to normal? Much love if so. Thanks!
Not for the first time, I wish there was a reset buttong.
  • The only explanation I can see is that your CC3 takes a shortcut, thinking that placing a river will make the land more fertile, thus farmable. Apart from that ...
    Are you using the right tools for the style? Perhaps the river fill style is not defined in the drawing and is just using the current fill style. Check by clicking "All DRawing Tools", opening the "Advanced" dialog and check the "Properties" of the river drawing tool.
  • Found it! Top right corner, there's a box that says "FS: " and a value. Mine said "Farmland" or something. Not sure how that happened, but if you click in the box, a "Fill Style Properties" window opens up. Select the first tab, "Brush Patterns" and I chose the second item, the one that looked like dark rivers.
    BTW this was only happening with fractal rivers (the usual ones I draw).
