Fractal path: Open or closed?
Hello,
I'm trying to draw an open fractal path, but the product will only allow me to draw closed paths...
More specifically, if I just click/click/right-click, the path will be open, but not with the fractalization parameters I was looking for. If at any time I press one of the arrow keys to customize the look of the fractal, then when I right-click, the path will be changed into a closed fractal polygon.
Is this a bug or am I doing something wrong?
FYI, I'm using CC3+ version 3.67.
Thank you all
Thank you all
As a workaround, instead of using the arrow keys to change the parameters, click the Fractalize button first, and set the desired parameters, but when you click OK, instead o selecting a line to fractalize, simply click the fractal path button, and draw your open path. The fractal path command will use the values set in the fractalization dialog.
If you are using a drawing tool, you must instead access the options for the draw method for that particular tool (Found by clicking 'Advanced' in the select draw tool dialog.
I finally go around it be drawing a simple path, then fractalizing it. You can see the result in this thread http://forum.profantasy.com/comments.php?DiscussionID=5595, it was used for the water in my Al Hajar city.
