Questions about SM: Castles! Compatability Update and Patch 7
I had a couple of questions about these:
1. For the time being, I do not have a working internet connection at the house where my computer and CC3 software reside. If I download Patch 7 and the Castles! compatability update at work and bring them home on my jump drive, will I be able to install them without needing an internet connection?
2. Is the Patch 7 update cumulative? I never got a chance to install Patch 6 and I do not have City Designer 3 yet.
3. Is Patch 7 required for the Castles! compatability update to work?
Thanks!
Thanks!
2. Yes.
3. Yes.
And take a look at the Fill Styles, Bitmap fills. You will see not just a list of fills you have in that template, you see an example of the bitmap fill.
JimP wrote: "And take a look at the Fill Styles, Bitmap fills. You will see not just a list of fills you have in that template, you see an example of the bitmap fill. "
I take it that's new and A Good Thing. :)
Just an update in case this is helpful to someone who has no internet at home: I didn't have to validate my serial number with the CC3 patch, but I did for the Castles! compatability update. And if you have any problems with getting the validation to work for Castles! (I kept getting an invalid serial number notification), re-dowload the update because Ralf fixed it this week because there was a problem with the validation code. But if you have an internet connection at home and didn't have a problem installing, don't worry about this.
