Yet another problem, Erase and Change Properties no longer select.
                    I was trying to work on a map and add a polygon background to the map to change its background in Cosmographer from a star field to a rocky terrain bitmap.   I got several errors including No draw tool, errors regarding Hull and Decks, and after I hit ok on the error messages I've discovered that Erase and the Change Properties now no longer create a little square at the tip of the arrow and I can no longer select anything with those tools.  Please help, this is really frustrating.   I tried switching to different maps, different layers/sheets, made sure layers or sheets I was on weren't fixed or hidden, I tried restarting the program several times and restarting my computer, all to no effect.  Is there a way to reset the controls to get this working again.
Also I'm using WIndows 7 and did install the program in a C:\ Profantasy directory using Install as Admin.
