These are the fixes: CC3+ Version 3.67 ================= - Fixed drawing style not always getting properly loaded on a new map - Fixed background selection in New Map Wizard not previewing correctly - Updated CC3MenuConfig.exe for more reliable menu update during installation - Fixed Draw menu calling wrong version of Offset command - Fixed Dungeon menu not showing Print Wizard option - Fixed Offset command not working on City Designer templates - Fixed Change House Layer command not working correctly
The fact that you didn't get this information means that the patch failed to update the readme.txt in the documentation folder, which may mean that the patch didn't get properly installed. I would try to install it again.
CC3+ Version 3.67
