Help - CC3+ not recognizing addon
                    Just bought the new trifecta - it's awesome - I'm having a technical issue however with DD3 not showing in the 'Tools -> Add Ons' menu after installation - DD3SetupForCC3Plus.exe was installed successfully without hangup. Thanks in advance for any help.
I installed CD and DD for CC3plus (CC3plus is on the installer exe name, so yes they are the correct installes for CC3+)
I have only malwarebytes and I have it disabled for the install.
I even set the executable for the installers as Admin permissions.
I do see the dll's in the folder which have CD and DD (CD2, XPDD2 and XPDD2_cc3) So I'm assuming these have indeed really installed. I even re-ran the installers to repair.
I still don't have them listed as addons in cc3plus. (and I set cc3plus to run as Admin as well.)
If I look at Symbol manager, I do see sconces torches for walls and portcullis' and other wall decor... so??
Anything else I should do? (Running Win7)
Report: Thanks that worked
SS1 doesn't have it's own menu set, so it is correct behavior that you won't see a menu entry or toolbar button. SS1 uses the standard overland menus. Just use the new map wizard to start a new SS1 map (overland category), and you have everything ready.
