2012 Annual Download Issue (Annual is corrupted)
I am wanting to install annual #6 from 2012 with Herman Weilinks symbol set. But I am getting this error every time. I do have CC3 and update 11 already downloaded. Here is the error..
InstallAware Wizard
"Cannot start setup - the setup file may be corrupt or you may have the wrong password. If you download this file, please download a fresh copy. If the file is password protected, check your password and try again."
I did and i even switched browsers as well as ran it as an administrator. Still the same error. Never had this issue before. On Windows 7. Using Regular CC3. 2011 Annual installed fine.
Actually, All I really want is to be able to install Herwin Wielinks Second Symbol set, I believe it was decembers and the satellite symbol set from the same annual as well. I am unsure how to install separately.
If you can help I would really appreciate it. Thanks.
InstallAware Wizard
If anyone knows a safe method to refresh/delete the Windows installer cache, please point me to it. I haven't been able to find anything reliable and safe through my searches.
Also the dropbox file you gave me if I need to reinstall again, it's expired.
I have Herman's Wielink's second addition symbols (November) in the correct symbol folder but for some reason won't load when I choose his theme. Only his first theme does (April) from Annual Vol 6 2012. Is my CC3 corrupt?
If you check the Structures catalog of the style and it contains Elf, Orc and Dwarf cities, you do have the full combined style, as these were in part II.
