CC3 Not Working Since CC3+ Installed
Hi All
Ive installed the update to CC3+ (DD3) and that works fine.
BUT
Now when i use CC3 (old) it wont open at all and just keeps crashing.
Any ideas ?
BUT
Any ideas ?
Can you do a repair install of CC3 (or simple the CC3 Udpate 11)? Does that fix CC3?
You can also try to delete the following registry entry, so that CC3 starts without a map pre-loaded (if the problem is with the last map opened in cc3):
HKEY_CURRENT_USER\Software\EvolutionComputing\CampaignCartographer3\WorkingDrawing
