Cosmographer 3 icon Random rotation?
I can't seem to figure this out, so I am reaching out to everyone here.
I am using Cosmograher 3 to make some deck plans. I'm trying to put some cargo in the hold, and I want to have the symbols rotate randomly. However I can't seem to get this to work, and the help files don't shed much light on the subject.
All I have been able to find is: check the box in the symbol display window. However no matter how many times I click the box, nothing changes.
So... How can I get the symbols to automatically rotate?
PS: I'm using the vector symbols
    If you want to change it only in the map you're drawing do the following:
    - click the symbol in question once.
    - open Symbols > Symbol Manager
    - select the symbol and click "Options"
    - check "Random Transformations" and click "Options"
    - choose "Rotate" and set a range of "360" degrees
    If you want to make that change permanent for all maps, you need to open the symbol catalog in CC3 and do the same thing there.
    Note that you can edit multiple symbols at once if you select them all in the Symbol Manager.
