CC3+ Update 1 Patch Is In Downloads
The Update 1 Patch for CC3+ is in the downloads for CC3+ now.
Also, the CC3+ version CA99 can be downloaded now too.
I even tried a repair after the initial update, afterwards, and nothing.
Also, if you haven't done so already, right clicking on the patch installer and choosing run as admin never hurts. I have encountered problems where programs that are supposed to elevate themselves fail on some systems for some reason.
I had this dreadful moment when I realised all my fill styles (custom and CC3+) and custom macros (not in the FCW32.mac, but in their own custom files) have disappeared!
I fact, everything contained in the C:\ProgramData\Profantasy\CC3Plus folder was somehow moved in the next folder (namely C:\ProgramData\Promethean\Profantasy\CC3Plus) so I was able to retrieve everything.
I also now have a ProgramData\{lots of hexadecimal} folder containing files like CC3PlusUpdate1.dat .exe .msi .par .res
What should I do with this folder? Keep? Erase? Move elsewhere?
So now everything is ok for me but if you have trouble, take a peek in your ProgramData folders to see if files where not moved where they do not belong...
Oh and the Tip of the day form is desperatedly empty...
Faulting application name: fcw32.exe, version: 0.0.0.620, time stamp: 0x54eb88d8
Faulting module name: Effects.dll, version: 0.0.0.0, time stamp: 0x54f47779
Exception code: 0xc0000005
Fault offset: 0x00002e7e
Faulting process id: 0x284
Faulting application start time: 0x01d05c45069bc759
Faulting application path: C:\Program Files (x86)\ProFantasy\CC3Plus\fcw32.exe
Faulting module path: C:\Program Files (x86)\ProFantasy\CC3Plus\Effects.dll
It appears to crash in the Effects.dll module.
The Update download should perhaps be corrected or removed to avoid further problems. Lost quite a lot figuring things out before finding this thread.
As Ralf previous mention an uninstall/install fixes the issue.
