Printing Issue
I have created several overland maps with CC3 with a scale of 300x200. My problem is that I can't seem to print the entire map on a 8.5x11 sheet of paper. No matter what view. Everything and active window always cuts of the right edge of the map. Need assistance because color is getting low in printer
I also highly recommend downloading a free pdf print driver. This will print your map to a pdf which you can then check to make sure it is correct then use to print to paper. Doing this has saved me a lot of ink over the years. A couple of free pdf printers are CutePDF, PDF995, and PDFCreator.
