CC3 - More than one custom palette?
I was wondering if there was a way of having more than one custom palette when making maps in CC3. I didn't find a way of doing this within the software but I thought maybe the palette was saved to a file I can store somewhere and switch them out that way.
Anyone know this?
    Yes, the custom palette is saved as FCW32.PAL in the CC3 program folder. You can make copies of that for later use and swap them out, but you need to handle that externally in Windows Explorer.
    Normally the better method is to store your custom palette with the drawing: File > Drawing Properties > (Custom Palette) Attach to Drawing. If you do this on a template, all maps created from that will use the custom palette.
  • Great, I didnt know about that feature, thanks s ton!
