5 sided house has 6 sides
Under CD3
1) Select House
2) Select House Shape -> pentagon shape
Image in preview has 5 sides.
3) Select Insert
A 6 sided building is placed. I don't really see this as a problem beyond the false advertising of it all. No settings or options appears to affect this.
    The five-sided preview is just one of unlimited options - the option is for any regular-side shape. When you click "Insert" after choosing this shape, take a look at the command line at the lower left of the screen. You'll see the [6] as the default number of sides for the polygonal house. Just type in any number and hit return to change the number of sides (e.g. "5" for a pentagonal house).
  • arcarc Newcomer
    I tried 5, 6 and 12 which worked fine. I'll assume all the rest of the integers there are also work. Thanks for the pointer.
