CC3 newbie question about hull design
I've been messing with CC3 for a few days now (loving it btw), and I've run to something of a snag that I cant seem to unravel.
Essentially, I would like to design an outer hull view for the ship i'm working on, but I cant get the hull to show depth. The edges of my hull show contours, but any time I try to add another hull piece onto of the existing hull, all edging disappears. I feel like i'm missing something extremely simple, or i'm going about this completely wrong.
Any advice would be greatly appreciated. :)
    You will need to add a second HULL sheet (For example HULL LOWER or HULL UPPER) and draw the new piece of hull on that. Duplicate the effects from the original HULL sheet (and adjust them a bit if you like).
    A sheet is always taken in its entirety when applying effects, that's why thinks like glows and bevels don't show up on interior pieces when you have them on the same sheet.
  • Thanks Ralf, that worked perfectly!
