All Profantasy software on Wine (tutorial)
                    I just wrote a tutorial to install CC3 and all the addons on Linux.
You can download the PDF here: https://drive.google.com/folderview?id=0B51GMCzkXp9IQlhwVC1yYlphbzA
Together with the PDF you can download the archive script.tar.gz, which contains a script to help you with Wine configuration through the tutorial.
I use CC3 on Arch Linux, but I hope the tutorial will work also on other distributions.
Maybe you can use this discussion to report if your distribution and Wine version are working.
Has anyone else had issues getting City Designer 3 to install on Wine, though? I've run through 3 or 4 different error messages. Most recent is below.
(after inputting serial#)
fixme:ntdll:NtLockFile I/O completion on lock not implemented yet
fixme:sfc:SFC_3 0
err:ole:create_server class {000c101c-0000-0000-c000-000000000046} not registered
err:ole:CoGetClassObject no class object {000c101c-0000-0000-c000-000000000046} could be created for context 0x4
fixme:advapi:RegisterEventSourceA ((null),"MsiInstaller"): stub
fixme:advapi:RegisterEventSourceW (L"",L"MsiInstaller"): stub
fixme:advapi:ReportEventA (0xcafe4242,0x0002,0x0000,0x000003f7,(nil),0x0006,0x00000000,0x50fc698,(nil)): stub
fixme:advapi:ReportEventW (0xcafe4242,0x0002,0x0000,0x000003f7,(nil),0x0006,0x00000000,0x22df160,(nil)): stub
fixme:advapi:DeregisterEventSource (0xcafe4242) stub
fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
fixme:shell:SHAutoComplete stub
fixme:win:WINNLSEnableIME hwnd 0x10234 enable -1: stub!
fixme:urlmon:InternetBindInfo_GetBindString not supported string type 20
fixme:wtsapi:WTSUnRegisterSessionNotification Stub 0x10078
At which point it crashes.
Searching on "fixme:urlmon:InternetBindInfo_GetBindString not supported string type 20" suggests I might need Gecko. Will post again if that fixes it.
microsoft rich edit 2.0
Rich Edit 4.1
microsoft visual C++ 2013 (12.0) ( for cc3 you may need earlier versions )
msls31
wine gecko (32-bit)
dotnet (2.0),(4.0),(4.5),(4.5.1) (only for cc3)
Uniscribe
so once this packages have been installed it is just a matter of running the base install program for cc3 or cc3+
you might want to use a "bottler" type program to automate the winetricks stuff
the only thing you may find is the text on some of the pre made maps are a little screwy
Hope this helps
Rob
After updating to the most recent version of Winetricks I was able to install, in a clean wine prefix, up to dotnet45 and vcrun2015. Unfortunately, at that point gandalfmagic's lovely little script wouldn't execute. It worked in Wine 1.6 with Winetricks2014-something, but in Wine 1.8 and/or Winetricks20160724 it claimed it was a bad EXE. I may still try reverting and using a clean prefix, but not tonight.
That said, using your list of necessary DLLs and PlayOnLinux it all installed flawlessly - well, once I figured out what I was doing with POL.
Thanks for all the help!
For unexplained reasons, my previous install of CC3 Plus quit launching and I decided it was time to upgrade my system anyway. Reinstalling now in Mint 18, again using PlayOnLinux, I discovered that not only is msi2 not available, Wine can't find Rich Edit 2.0 anymore. So we went and tracked down the DLLs. According to Clamav, as of 10/7/2016 both of these files are clean:
http://manydlls.org/riched20.dll/en-download-15736.html
http://api.256file.com/msftedit.dll/en-download-92914.html
I downloaded them directly into the System32 folder of the appropriate wine prefix and then attempted to install CC3 and got the error in the attached screenshot.
CC3+ launches, then appears to crash but remains open. If I have time (or if it won't save or something) I'll dig into the backtrace later, but it only seemed right that I contribute a bit, as well.
While not Linux, I decided to give CC3+ a shot using Wine on MacOS Sierra. After an initial "glitch" during installation (having to do with the serial number, but later mysteriously fixed itself), everything installed fine and appears to work fine. No special changes were made of any kind.
I did install Wine using the instructions found here: https://www.davidbaumgold.com/tutorials/wine-mac/.
As this is the latest Wine build, that may also have something to do with the success.
